Android PDF Viewer SDK 3.10 9 years 6 months ago #11717
A new version 3.10 RC has been published.
3.10RC
native library
- NEW font embed engine, which supports better Arabic RTL writing and CJK Vertical writing.
- ENHANCED update freetype font to 2.7.1
- ENHANCED project's strings translation added (Arabic, French, Italian and Spanish)
- FIX fixed font lock issue in some rare case
- FIX text search issue for Arabic.
- FIX multi-thread risks both on native and java side.
- FIX issue with 64bits platform (some fonts rendered as wrong glyphs)
- FIX small fixes and optimizations
Android PDF Viewer SDK 3.10 RC 2 9 years 6 months ago #11742
A new version 3.10 RC 2 has been published.
3.10RC2
native library
- NEW interface Document.GetEmbedFileDesc(); to get Desc field of the file specification dictionary (from table 3.41 of the PDF 1.7 spec)
- ENHANCED added the ability to set curl back side color in PDFViewCurl.
- ENHANCED text search for Arabic.
- FIX unicode chars issue for dots in special PDF file
- FIX issue with a colorspace name not found in a specific file.
Android PDF Viewer SDK 3.10 9 years 6 months ago #11757
The stable version 3.10 has been published.
3.10
native library
- NEW interface: Annotation.GetModifyDate(); and Annotation.SetModifyDate();
get/set modify DateTime of Annotation.
DateTime String object format as (D:YYYYMMDDHHmmSSOHH'mm') where:
YYYY is the year
MM is the month
DD is the day (01–31)
HH is the hour (00–23)
mm is the minute (00–59)
SS is the second (00–59)
O is the relationship of local time to Universal Time (UT), denoted by one of the characters +, -, or Z
HH followed by ' is the absolute value of the offset from UT in hours (00–23)
mm followed by ' is the absolute value of the offset from UT in minutes (00–59)
more details see PDF-Reference-1.7 section 3.8.3
- ENHANCED Annotation.GetPopupLabel and Annotation.SetPopupLabel to meet with PDF-Reference-1.7 (Markup Annotations pages 615 to 619)
these annotations can't add PopupWindow as child:
Link, FreeText(Editbox added by us, not form field, popup value is in displayed edit text)
Movie, Widget(Form Field), Sound, Screen, PrintMark, TrapNet, WaterMark, Popup
these annotations can't get/set Popup Values:
Link, Movie, Widget(Form Field), Screen, PrintMark, TrapNet, WaterMark, Popup
these annotations set PopupText same as edit text:
FreeText
- ENHANCED Annotation.SetIcon(name, PageContent)
redesigned to:
Annotation.SetIcon(name, DocForm)
- FIX issue for freetype compile on 64 bits CPU.
- FIX issue with type3 font char width in certain pdf.
Android PDF Viewer SDK 3.10b 9 years 6 months ago #11764
A hot fix to 3.10 has been published as 3.10b
3.10b
native library
- ENHANCED Adding some config variables to Global class.
- FIX a small issue with create pages and create editbox on page
Android PDF Viewer SDK 3.10 9 years 5 months ago #11816
A fix to 3.10 has been published as 3.10c
3.10c
native library
- FIX issue for some unembedded font.
- FIX page flatting issue for some special PDF.
