Android 5.x or Font display problem 9 years 5 months ago #11981
  • vkjha
  • vkjha's Avatar Topic Author
Dear RadaeePDF Team,
I have implemented RadaeePDF library read and fill PDF forms.
I have implement every thing but i have problem. when i tries to add value in Edit Text Box then value is converted in symbols in Android 5.x series(Lollipop) only and other release are working.
previously i interact with your team, they team provide solution, "This error is font issues", they told to me you have used non-italic font but i am not able to used not-italic font in library or project.
I need to request to your team please provide me the solution.
Sharad Balaji
Android 5.x or Font display problem 9 years 5 months ago #11983
The first solution: you need to check Wrong non latin fonts rendering on Android 5.x , it's a more generic solution (it should work we have tested it)
Then We have checked your file, it use's Times New Roman, so try to set the annot font to it's freetype mapping "Tinos".
In Global.Init, replace setAnnotFont("DroidSansFallback") with:
setAnnotFont("Tinos")
But this is a file specific solution that could cause problems with other files.
