Android PDF Viewer SDK 3.15 8 years 5 months ago #13413
A new version 3.15 has been published.
3.15
native library
- NEW added the handling of graphical (not-graphometric and not-certified) signature for sign form fields.
Note: the added signature might not be rendered using other readers like (Acrobat desktop version) as it's handled via setIcon to disable this feature modify Global.sEnableGraphicalSignature.
- NEW interface Annotation.IsListMultiSel() (to indicate if the list is multi/single choice)
- NEW method Annotation.GetAdditionalJS() to get additional java script actions for annotation.
- NEW method Annotation.SetEditText(value, formatted) to set both value and appearance for edit box field.
- ENHANCED improvment in the demo project
- ENHANCED optimize for Radial Gradient Filling.
- ENHANCED optimize for postscript parsering, and call.
- ENHANCED optimizations for Jpsg2000 decoding (for available 3+ cores processors).
- FIX a rendering issue while setting specific stroke color.
- FIX rendering issue for password form fields.
- FIX an issue while flattening a pdf.
- FIX a crash issue with specific file.
- FIX an issue with specific file because of bad data.
- FIX clipping issue with certain pdf file.
- FIX open/import from a special pdf file.
- FIX a performance issue for Linear Gradient Filling.
