Android PDF Viewer SDK 3.15.1 beta 8 years 5 months ago #13456
A new beta version 3.15.1beta1 has been published.
3.15.1beta1
native library
- ENHANCED optimized rendering performances for PostScript.
- FIX a wrong rendering issue for special PDF file.
Android PDF Viewer SDK 3.15.1 beta 8 years 4 months ago #13542
A new beta version 3.15.1beta2 has been published.
3.15.1beta2
native library
- FIX a rendering crash issue, where there is bad data.
Android PDF Viewer SDK 3.15.1 beta 8 years 4 months ago #13573
A new beta version 3.15.1beta3 has been published.
3.15.1beta3
native library
- FIX performance issue for import page.
- FIX issue for inline image (in specific file)
Android PDF Viewer SDK 3.15.1 beta 8 years 4 months ago #13613
A new beta version 3.15.1beta4 has been published.
3.15.1beta4
native library
- FIX an issue while opening a certain file.
Android PDF Viewer SDK 3.15.1 beta 8 years 3 months ago #13642
A new beta version 3.15.1beta5 has been published.
3.15.1beta5
native library
- NEW interface PDFFinder.GetEndChar(int index) to get the end char index of the given search match
- NEW interface Page.FindOpen which treats line break as blank char and ignors them while searching.
can be used using PDFLayoutView.PDFFindStart(String key, boolean match_case, boolean whole_word, boolean skipBlank) www.radaeepdf.com/support/knowledge-base?view=kb&kbartid=130
- ENHANCED optimization for PDFAssetStream java class
- FIX rendering issue when edit field has empty appearence, but has non-empty text value.
Android PDF Viewer SDK 3.15.1 beta 8 years 3 months ago #13733
A new beta version 3.15.1beta6 has been published.
3.15.1beta6
native library
- FIX a performance issue while loading a specific pdf with form fields.
