Android PDF Viewer SDK 3.15.1 8 years 3 months ago #13749
A new version 13.15.1 has been published.
3.15.1
native library
- NEW interface PDFFinder.GetEndChar(int index) to get the end char index of the given search match
- NEW interface Page.FindOpen which treats line break as blank char and ignors them while searching.
can be used using PDFLayoutView.PDFFindStart(String key, boolean match_case, boolean whole_word, boolean skipBlank)
- ENHANCED optimization for PDFAssetStream java class
- ENHANCED optimized rendering performances for PostScript.
- FIX rendering issue when edit field has empty appearence, but has non-empty text value.
- FIX a performance issue while loading a specific pdf with form fields.
- FIX a crash issue while openeing certain files.
- FIX performance issue for import page.
- FIX issue for inline image (in specific file)
- FIX a rendering crash issue, where there is bad data.
