Android PDF Viewer SDK 3.15.2 beta 8 years 2 months ago #13796
A new beta version 3.15.2beta1 has been published.
3.15.2beta1
native library
- ENHANCED support of Arabic search with vowel signs except ( Search unsupported Arabic signs )
- FIX flush screen issue after modifying a check box value.
- FIX issue for a very large image.y large image.
Android PDF Viewer SDK 3.15.2 beta 2 8 years 2 months ago #13818
A new beta version 3.15.2beta2 has been published.
3.15.2beta2
- ENHANCED remove mips and mips64 libraries, as they are no longer supported by Android NDK.
- FIX a freeze issue when calling objsStart() on a specific file.
Android PDF Viewer SDK 3.15.2 beta 3 8 years 1 month ago #13886
A new beta version 3.15.2beta3 has been published.
3.15.2beta3
- FIX rendering issue with a specific file.
- FIX issue for OverPrint mode
- FIX highlight issue with specific file.
Android PDF Viewer SDK 3.15.2 beta 4 8 years 1 month ago #13887
A new beta version 3.15.2beta4 has been published.
3.15.2beta4
- NEW interface Document.GetPageLabel(int pageno) to get the custom page label
Android PDF Viewer SDK 3.15.2 beta 5 8 years 1 month ago #13907
A new beta version 3.15.2beta5 has been published.
3.15.2beta5
- FIX check-box issue with a specific file.
Android PDF Viewer SDK 3.15.2 beta 6 8 years 1 month ago #13931
A new beta version 3.15.2beta6 has been published.
3.15.2beta6
- ENHANCED Javascript app.alert now support non-object parameter
- FIX issue for edittext field, which has wrong data (appearence not match text content).
- FIX a highlight issue with a certain pdf file.
