Android PDF Viewer SDK 3.15.2 8 years 1 month ago #13941
A new Android version 3.15.2 has been published.
3.15.2
- NEW interface Document.GetPageLabel(int pageno) to get the custom page label
- ENHANCED Javascript app.alert now support non-object parameter
- ENHANCED remove armeabi, mips and mips64 libraries, as they are no longer supported by NDK .
- ENHANCED support of Arabic search with vowel signs except (Shadda with other signs) check ( Search unsupported Arabic signs )
- FIX issue for edittext field, which has wrong data (appearence not match text content).
- FIX a highlight issue with a certain pdf file.
- FIX rendering issue with a specific file.
- FIX check-box issue with a specific file.
- FIX issue for OverPrint mode
- FIX a freeze issue when calling objsStart() on a specific file.
- FIX flush screen issue after modifying a check box value.
- FIX issue for a very large image.
