Android PDF Viewer SDK 3.50 7 years 9 months ago #14145
  • support's Avatar Topic Author
- FIX changed the multiline text edit because of the different way Android 7.x+ is managing someway transparencies
- CHANGE changed Arimo as default annotation's font
native libs:
- FIX applied workaround to avoid some corrupted PDF files breaking form fields' contents
3.50 RC4
- REMOVED the configuration parameter fit_different_page_size. The feature is still unfinished and it's not yet officially supported.
native libs:
- FIX rendering issue with uncommon transparency setting
- FIX broken GetPageLabel() behavior
documentation
- UPDATE References to some third part code
3.50 RC3
- FIX Fixed the lack of refresh just after zoom in in not-OpenGL rendering framework
- FIX Out of bounds while getting the actual page with some quick movement on some Samsung devices
- TODO Still working on fit_different_page_size behavior which is calculating the wrong scale factor with some PDF documents.
WE'VE FOUND A MAJOR ISSUE IN ZOOM GESTURE: WHEN GESTURE ENDS THE PAGE (IN NON-OPENGL MODE) IS NOT REFRESHED UNTIL ANY PAN MOVEMENT HAPPENS.
WE WILL FIX IT IN RC3.
3.50 RC2
- NEW Introduced the new configuration parameter fit_different_page_size which allow the rendering engine to set different scale factor for different pages.
- FIX Version name in Global.java is reflecting the
native libs
- FIX Wrong rendering behavior when an empty filling path was evaluated as a rectangle filling.
3.50 RC
- NEW Completely new OpenGL based framework. It uses GPU rendering. Speed is increased by a 2x / 5x depending on GPU performances
- NEW Curl effect relaying to OpenGL rendering engine
- NEW view class source is now distribute with the framework
- FIX improved null check for some unexpected circumstances while drawing pages
- FIX some code clean up
native libs
- NEW major update of libjpeg library. Faster and more secure.
- FIX is some circumstances widget fields was not hide when .Hide(true) was set
- FIX some fixes related to special cases
- UPDATE built with last Google NDK
documentation
- UPDATE Reflects the introduction of new OpenGL framework
Last edit: by support.
