Android PDF Viewer SDK 3.53.3beta 6 years 6 months ago #14866
A new version 3.53.3beta1 has been published.
3.52.3beta1
native libs
- ENHANCED Remove buffer limit from Document.SetMeta/GetMeta.
Android PDF Viewer SDK 3.53.3beta2 6 years 6 months ago #14874
A new version 3.53.3beta2 has been published.
3.52.3beta2
native libs
- FIX invoking Document.ImportPage() on a memory modified stream object in a PDF file.
Android PDF Viewer SDK 3.53.3beta 6 years 5 months ago #14884
A new version 3.53.3beta3 has been published.
3.52.3beta3
native libs
- ENHANCED optimize tensor pattern rendering.
- ENHANCED optimize overprint (enabled only using render mode = 2)
- FIX crash issue when calling setMeta() with very long strings.
- FIX issue for 90 or 270 degrees rotated image, and with any direction flip.
- FIX rectangle color in case of empty highlight annotation.
Android PDF Viewer SDK 3.53.3beta 4 6 years 5 months ago #14890
A new version 3.53.3beta4 has been published.
3.52.3beta4
native libs
- FIX rendering issue in case of overprint.
Android PDF Viewer SDK 3.53.3beta 5 6 years 5 months ago #14891
  • luca.f
  • luca.f's Avatar
  • Thank you received: 10
A new version 3.53.3beta5 has been published.
3.52.3beta5
native libs
- Sped up tiling pattern rendering, when thousands of tiling pattern need to be drawn.
- Fixed jpx decode issue
Android PDF Viewer SDK 3.53.3beta6 6 years 5 months ago #14894
A new version 3.53.3beta6 has been published.
3.53.3beta6
- Java code optimization in GL mode.
native libs
- ENHANCED optimize rendering of a pdf that contains a huge image.
