Android PDF Viewer SDK 3.53.3 6 years 4 months ago #14926
  • luca.f
  • luca.f's Avatar Topic Author
  • Thank you received: 10
The new stable release has been published.
3.53.3
- Java code optimization in GL mode.
- Java code Fix memory leak in GL Reflow mode.
native libs
- ENHANCED Remove buffer limit from Document.SetMeta/GetMeta.
- FIX invoking Document.ImportPage() on a memory modified stream object in a PDF file.
- ENHANCED optimize tensor pattern rendering.
- ENHANCED optimize overprint (enabled only using render mode = 2)
- FIX crash issue when calling setMeta() with very long strings.
- FIX issue for 90 or 270 degrees rotated image, and with any direction flip.
- FIX rectangle color in case of empty highlight annotation.
- FIX rendering issue in case of overprint.
- ENHANCED Speed up tiling pattern rendering, when thousands of tiling pattern need to be drawn.
- FIX a jpx decode issue with certian pdf.
- ENHANCED optimize rendering of a pdf that contains a huge image.
- FIX "whole word" flag issue.
- ADD new global variables.
- FIX issue caused by null object into content stream of Annotation.
