Android PDF Viewer SDK 3.53.5beta7 6 years 1 month ago #15080
  • luca.f
  • luca.f's Avatar Topic Author
  • Thank you received: 10
A new beta has been released of Android PDF Viewer SDK
3.53.5beta7
native libs:
- FIX crash issue for special PDF file (divide by zero).
3.53.5beta6
- NEW method Annotation.flatFromPage() to flate single annotation.
- NEW method Annotation.GetStrokeDash().
- REMOVE all members in Document class.
- ENHANCED inner class in Document optimized.
- ENHANCED add some member to PDFViewController.
- ENHANCED Grid Thumb Item has new method get_path();
3.53.5beta5
native libs
- Java code fix OpenGL fling in dual page mode.
- REMOVE deprecated module PDFReader.
- FIX undo/redo stack issue, some times annotation order is massed.
3.53.5beta4
- Java code fix the issue page changing while zooming in dual page mode.
- Java code fix OpenGL zooming
- Java code ENHANCED Added the possibility to control annotation properties
3.53.5beta3
- Java code add Global.fling_speed to GLLayoutDual
native libs:
- FIX encoding issue for truetype, in some special condition.
3.53.5beta2
native libs
- FIX crash on special pdf
3.53.5beta1
native libs
- ENHANCED image rendering and transparency group rendering by checking drawable area.
- ENHANCED image scaling percision.
- FIX issue with RenderToBmb in case of a specific file.
Last edit: by luca.f.
