Android PDF Viewer SDK 3.53.5b 6 years 4 days ago #15169
  • luca.f
  • luca.f's Avatar Topic Author
  • Thank you received: 10
A new version has been published.
3.53.5b
- NEW add new class GLLayoutDual2, that scroll single/dual pages in vertical way.
- NEW Added the possibility to control annotation properties
- ENHANCED Disable Https trust all hosts behavior (causes a security vulnerability)
- ENHANCED remove all members in Document class.
- REMOVE deprecated module PDFReader.
- FIX OpenGL fling in dual page mode and zooming.
- FIX an issue for single and dual layout scrolling.
- FIX undo/redo stack issue, some times annotation order is massed.
native libs
- NEW method Annotation.flatFromPage() to flate single annotation.
- NEW interface Annotation.GetEditTextAlign(), Annotation.SetEditTextAlign(), Annotation.GetStrokeDash()
- ENHANCED reflow mode, now can reflow some transparency group.
- ENHANCED now SetInkPath() will calculate annotation area automaticaly.
- ENHANCED ObjsGetCharUnicode() will return -2, mean the transparency object.
- ENHANCED image rendering and transparency group rendering by checking drawable area.
- ENHANCED image scaling percision.
- FIX issue calling Annotation.SetInkPath() will change the stroke width.
- FIX a crashed issue to load freed annotation (some PDF tool seems not delete reference from page, when annotation deleted)
- FIX Annotation.RenderToBMP() issue.
- FIX Square and Circle annotation issue for setRect().
- FIX issue for Page.ImportAnnot() when page is rotated page.
- FIX crash issue for special PDF file (divide by zero).
- FIX OverPrint is disabled when CMYK color space data is load from ICC data file.
- FIX encoding issue for truetype, in some special condition.
- FIX issue with RenderToBmb in case of a specific file.
- FIX When rendering a PDF with transparent images, the SDK renders a grey box instead of transparent colors.
- FIX crashed issue when linerazed data damaged
