RadaeePDF Classic for Android 3.60.0, released 5 years 1 week ago #15536
  • support's Avatar Topic Author
The version 3.56 RC is now stable. It contains so many improvements and new features and we decided to change its version number to 3.60!
3.60.0
- NEW use signature API to handle signature fields
- NEW updated icons and introduced global color setting
- NEW polygon and polyline annotation support
- NEW edit text box annotation support
- NEW changed Symbol font mapping: moved from Symbola to Symbol Neu because of license's change
- NEW Symbol Neu mapping is now compliant to non UTF-8 Symbol font
- ENHANCED SuperDoc() class is improved to better manage memory on low memory devices
- ENHANCED SuperDoc() has "legacy" parameter for legacy code
- ENHANCED zlib code rewritten and improved for speed (12% faster than before)
- ENHANCED improved how transparent images can be applied on a pageadding transparent images - Document.NewImage()
- ENHANCED "fit_different_page_size" when the PDFLayoutDual is set
- ENHANCED moved some closing operation in thread separated from the UI
- ENHANCED cleaned up the dialog box for annotations
- FIX clean up code to optimize memory consumption and prevent memory leaks
- FIX prevented potential ANR while closing the current file
- FIX wrong path detection was preventing the handling of bookmarks
- FIX some case was corrupting XREF
- FIX addContent was cutting contents when clip operator is used
3.56.0 RC
- NEW editbox annotation
- NEW polygon annotation
- NEW polyline annotation
