java.lang.UnsatisfiedLinkError 4 years 10 months ago #15614
  • jomart
  • jomart's Avatar Topic Author
Hello, Support.
Recently a user opened a PDF file and there was a crash when enter to the Global class in the line System.loadLibrary("rdpdf"). We are using RadaeePDF SDK 3.55.5.
The crash is about java.lang.UnsatisfiedLinkError: dalvik.system.PathClassLoader[DexPathListzip file "/data/app/com.xxxx.xxxx...../base.apk"].
I attach an image for better comprehension.
Could you help us?
Any information is appreciated.
java.lang.UnsatisfiedLinkError 4 years 10 months ago #15615
this issue happen only when dynamic library is missing.
depends on what CPU you are running.
in normally
we include abi:
arm64-v8a
armeabi-v7a
x86
x86_64
you shall check $PDFSample\ViewLib\src\main\jniLibs
if you are using cordova, plz check all these abi exists.
java.lang.UnsatisfiedLinkError 4 years 10 months ago #15616
  • jomart
We already have these abi in our project, this happened with a Samsung device SM-G570M. We updated the SDK version from Radaee 3.15.1 to 3.55.5.
Could be another thing?
java.lang.UnsatisfiedLinkError 4 years 10 months ago #15617
the log shall tell path of library load failed, and abi information shall include in path.
more: the log shall tell which C function Symbol the system are trying to load.
i need more details of log, may you attach here?
