How to pass certificate tools? 12 years 2 months ago #6214
  • cuongnd
  • cuongnd's Avatar Topic Author
I have used "Windows App Cirt Kit" to check my App after reference to RDDLib.
And it cannot pass:
Windows security features test
FAILED Binary analyzer
Error Found: The binary analyzer test detected the following errors:
RDPDFLib.dll has failed the WXCheck check.
RDPDFLib.dll has failed the SafeSEHCheck check.
Supported API test
FAILED Supported APIs
Error Found: The supported APIs test detected the following errors:
API GetModuleFileNameW in kernel32.dll is not supported for this application type. RDPDFLib.dll calls this API.
API GetModuleHandleW in kernel32.dll is not supported for this application type. RDPDFLib.dll calls this API.
API LoadLibraryExW in kernel32.dll is not supported for this application type. RDPDFLib.dll calls this API.
API LoadLibraryW in kernel32.dll is not supported for this application type. RDPDFLib.dll calls this API.
API lstrlenA in kernel32.dll is not supported for this application type. RDPDFLib.dll calls this API.
What can i do to pass the tests?
How to pass certificate tools? 12 years 2 months ago #6218
maybe not last version? we submitted APP to store...
How to pass certificate tools? 12 years 2 months ago #6221
  • cuongnd
I have used PDFViewer2.9.9.1b that have been downloaded in www.androidpdf.mobi/download/download-winrt
How to pass certificate tools? 12 years 2 months ago #6228
we'll check it, as now we are build a new frame, using ScrollViewer.
it may delayed, till new frame works, and new APP submitted.
