System.AccessViolationException 12 years 2 months ago #6303
  • Yeshveer
  • Yeshveer's Avatar Topic Author
Here I check your sample example for PDF view and Annotation for window 8.
While using the sample I am able to annot but when I have done with it and click on the done button . The application is crashing continuously with
coming all the time. Not able to detect using breakpoints and applying a try catch handler too.
Not able to find what is the cause.
I tried to change the access permission of the pdf file and provided all the permissions . Still giving the exception.
Please help.
System.AccessViolationException 12 years 2 months ago #6317
  • goldkyo
  • goldkyo's Avatar
  • Thank you received: 2
This may be an internal defect from VS 2013. Please refer to:
connect.microsoft.com/VisualStudio/feedb...add-data-connections
And you can try to solve this problem by running command "netsh winsock reset" as Administrator. Thank you.
