NewImageJPEG always returns nullptr 12 years 1 week ago #6693
  • Einstein
  • Einstein's Avatar Topic Author
using this code I was unable to draw a JPEG using your pdf library:
pageContent->GSSave();
auto imagePosition = imageShape->Position;
auto imageMatrix = ref new RDPDFLib::pdf::PDFMatrix(1, 1, imagePosition.X, imagePosition.Y);
pageContent->GSSetMatrix(imageMatrix);
auto abc = imageShape->File;
auto documentImage = document->NewImageJPEG(abc);
auto pageImage = page->AddResImage(documentImage);
pageContent->DrawImage(pageImage);
pageContent->GSRestore();
document->NewImageJPEG(abc) always returns nullptr on several images. I've triple-checked that imageShape->File is always a valid path to a JPEG file.
P.S. Is there a way to use Document.NewImage(Bitmap, boolean) using the WinRT bindings?
(this one: www.androidpdf.mobi/documentation/javado...cument.html#NewImage(Bitmap, boolean))
NewImageJPEG always returns nullptr 12 years 1 week ago #6694
a premium license is needed for this method and SetCache() need to be invoked.
like:
doc.Open( "pdf path-name" ); //must be writeable.
doc.SetCache( "temp path-name" ); //must be writeable.
The following user(s) said Thank You: tien4720
NewImageJPEG always returns nullptr 12 years 1 week ago #6697
  • Einstein
Thanks very much! I got working. I have another question though. I'd also like to render PDF documents to images. I saw there's a PDFPage::RenderToBmp method that allows this, but it's missing from the Windows Phone library. Is it possible to render PDF documents to images on Windows Phone 8.1?
Last edit: by tien4720.
NewImageJPEG always returns nullptr 12 years 1 week ago #6698
yes, WP8 has some extra codes:
m_page.RenderPrepare();
int[] pixels = m_dib_tmp.Pixels;//where m_dib_tmp is WriteableBitmap object.
PDFPage.ResetBuf(pixels, m_dibw, m_dibh);//m_dibw is width of m_dib_tmp, m_dibh is height of m_dib_tmp.
m_dib = m_dib_tmp;
m_dib_tmp = null;
if (m_status == 2) return;
PDFMatrix mat = new PDFMatrix(m_scale, -m_scale, 0, m_dibh);
m_page.Render(pixels, m_dibw, m_dibh, mat, true, PDFView.renderQuality);
NewImageJPEG always returns nullptr 12 years 1 week ago #6699
  • Einstein
Hi, I'm using C++/CX on Windows Phone 8.1, could you provide me a sample code that would render a pdf page to a WriteableBitmap?
NewImageJPEG always returns nullptr 12 years 1 week ago #6700
it seems C++/CX can't access WriteableBitmap directly.
only way is: use int array instead.
