[Solved] Annotations and gestures 11 years 6 months ago #8314
  • Bloncourt
  • Bloncourt's Avatar Topic Author
I've already purchased the android sdk sometimes ago, and I'm very satisfied of your products.
Now I have a project to develop on a WinRT plateform. I tried some of your PdfViewer BETA, and the result looks promising for what we aim to do.
Anyway, I have a technical question regarding the freehand annotations.
Is it possible to distinguish when you are using a stylus (or a mouse) or when your are using the fingers ? What we are trying to do, is to separate the gestures from the use of the stylus, to be able to zoom or navigate with the fingers, and to annotate with the stylus, without toggle to activate.
Thank you in advance
Regards
Antoine
Last edit: by tdadone.
[Solved] Annotations and gestures 11 years 6 months ago #8334
  • Bloncourt
Solved using the PointerDeviceType check.
msdn.microsoft.com/en-US/library/windows...interdevicetype.aspx
Bloncourt
