Unable to load an ink annotation on a canvas 11 years 11 hours ago #9343
  • Pja
  • Pja's Avatar Topic Author
I am unable to load a particular ink annotation on a canvas for further editing it.
public void StylusPopUpshow(PDFAnnot annot, PDFVPage page, PDFDoc m_doc, PDFView m_view, ScrollViewer m_scroller)
if (!StylusCommentPopup.IsOpen)
StylusCommentPopup.IsOpen = true;
rect = annot.Rect;
int h = Math.Abs((int)(annot.Rect.bottom - annot.Rect.left));
int w = Math.Abs((int)(annot.Rect.right - annot.Rect.top));
m_bmp = new PDFBmp(w,h);
bmp = new WriteableBitmap(w,h);
bmp = m_bmp.Data;
bmp.Invalidate();
pg = page.GetPage();
mat = page.CreateInvertMatrix(0,0);
pg.RenderToBmp(m_bmp, mat, true, PDF_RENDER_MODE.mode_normal);
Image img = new Image();
img.Source = bmp;
Canvas.SetLeft(img, 10);
Canvas.SetTop(img, 10);
StylusCanvas.Children.Add(img);
StylusCanvas.UpdateLayout();
This is the code. Using this code the entire page is displayed on the canvas instead of the clicked annotation.
Can you help me with this?
Unable to load an ink annotation on a canvas 11 years 3 hours ago #9352
Windows SDK is lacking the PDFAnnot.RenderToBmp() method yet.
We will release an update with a lot of fixes and some missing method from Android and iOS version later next week.
The following user(s) said Thank You: Pja
Unable to load an ink annotation on a canvas 11 years 1 hour ago #9353
  • Pja
Thank you for your reply....
Will the next version of windows have the same updates like Android?
I need to buy the windows latest version for using in my project.
Can you please keep me updated about it?
Unable to load an ink annotation on a canvas 11 years 11 minutes ago #9354
  • Pja
I need to implement a feature in my project where i load the ink annotation on a canvas as a pop up so that i can edit it (also change the stroke color and width)
and after editing the ink annotation add the edited annotation on the same position on pdf.
Is this possible in windows library of your later versions or in paid version?
Please update me about this since i need it urgently in my project?
Unable to load an ink annotation on a canvas 10 years 11 months ago #9371
It won't be possible to alter ink paths.
The feature isn't available at the moment.
Only an annotation render to bitmap so you would be able to put it on your own canvas.
