Annotation misplacing 10 years 11 months ago #9394
  • Pja
  • Pja's Avatar Topic Author
hi,
I am using Radaee PDF for both windows and IOS, when I make an annotation on a PDF using iPad I am not able to spot the comment
on the exact same position on Windows 8 app.
What is the issue?
Please tell us the possible solution for the same.
Annotation misplacing 10 years 10 months ago #9547
  • adminjugaad
  • adminjugaad's Avatar
Your issue is not fully clear.
May you send us your annotating code on both iOS and Windows?
Maybe a couple of pdf file generated with your Apps on both platforms.
