Printing document 9 years 8 months ago #11440
  • skrblyk
  • skrblyk's Avatar Topic Author
Is it possible to print a Pdf document (with RadaeePDF for Windows8.1 or Windows 10)?
Printing document 9 years 8 months ago #11441
We're investigating about converting pdf to xps format.
It seems there isn't any native way.
If it'd right, the way might to render pages to bitmap and send them to the printer spooler.
The spooler could be driven with a code like that below:
PrintDocument pd = new PrintDocument();
     pd.PrintPage += (sender, args) =>
           Image i = Image.FromFile("C://tmp01.jpg");
           Point p = new Point(100, 100);
           args.Graphics.DrawImage(i, 10, 10, i.Width, i.Height);
     pd.Print();
We will work in integrating the sample code within one of the next releases.
The following user(s) said Thank You: skrblyk
