WACK issue 9 years 7 months ago #11505
  • kumar88
  • kumar88's Avatar Topic Author
when i ran the windows app certification kit i got certain errors, i am attaching them, please see that.
WACK issue 9 years 7 months ago #11513
Make sure that you are using the release builds with both projects, check the screenshot..
You can hit this error if your build runs the WACK tools against DEBUG builds as a custom step or you don’t have the .NET Native toolchain enabled for your RELEASE builds.
If you still have problems, can you send us more details about your configurations?
WACK issue 9 years 7 months ago #11530
  • kumar88
Thanks a lot for the information nermeen, I want to know how do you refresh the loaded pdfviewer on canvas, i.e when I remove a page from file I need to refresh the view to preview the changes
WACK issue 9 years 7 months ago #11532
For such a modification You can do like the following:
m_doc.RemovePage(pageno);
m_view.vZoom(m_view.vGetScale());
For a smaller modification, like adding/deleting/editing an anootation you can use, m_view.vRenderAsync or m_view.vRenderSync
WACK issue 9 years 7 months ago #11533
  • kumar88
I tried your suggestion but the issue is after the removal I need to scroll the pdf pages down & again up to see the changes , is there a way to reflect the change quickly (some thing like reloading...)?
WACK issue 9 years 7 months ago #11544
The above code is working in the demo project, without the need to scroll..
To reload, you need to save the doc, close and then reopen...check the below code in PDFReaderPage.xaml.cs
m_doc.Save();
vClose();
OnNavigatedTo
