which method is responsable for optimizing pages rendering after zooming ? 8 years 5 months ago #13497
  • Bouzidi
  • Bouzidi's Avatar Topic Author
I m using the last Windows sdk in my project and I need to know which method is responsable for optimizing pages rendering after zooming.
In fact, after zooming In the lib takes one second to optimize the rendering quality as qhown in this two files :
Before render optimization :
drive.google.com/file/d/1ljJExBwOhiPwonr...ZSH/view?usp=sharing
After render optimization :
drive.google.com/file/d/1efwLZEeiilTKbVU...RT2/view?usp=sharing
Can you explain us the process timeline of the pages rendering.
Waiting for your response.
Best Regards,
Hamza.
which method is responsable for optimizing pages rendering after zooming ? 8 years 5 months ago #13498
Dear Hamza,
While zooming, a low quality bitmap is used for rendering (to avoid a white page), after zooming the bitmap is rendered till the high quality rendering is finished (this depends on the page content, fast for light-weight pages, less faster for heavier pages).
Methods responsible for zooming behavior:
PDFView.ZoomStart
PDFView.ZoomSet
PDFView.vOnTimer
PDFView.vDraw
The following user(s) said Thank You: Bouzidi
which method is responsable for optimizing pages rendering after zooming ? 8 years 5 months ago #13499
  • Bouzidi
Dear Nermeen,
Would you please give us the low quality bitmap name ?
Thank you,
which method is responsable for optimizing pages rendering after zooming ? 8 years 5 months ago #13500
Dear Hamza,
The bitmap is instance of PDFBmp and gets generated and rendered at runtime, please check PDFVPage.Draw(PDFVCanvas canvas, float scrollx, float scrolly) which gets called from PDFView.vDraw in case m_drawbmp is true
