Print fearture 7 years 10 months ago #14136
  • gongtom
is there a print feature in the viewer for UWP like in android and ios versions of the radaeePDFViewer?
Thomas.
Print fearture 7 years 9 months ago #14148
Sorry for delay.
Windows has no standard API to print PDF files.
To print them you shall instantiate the Windows printer spooler and fill it with rasterized bitmaps.
Each bitmap shall be scaled to the proper size to satisfy printer density.
Such a way to print is not network and performances friendly.
The following user(s) said Thank You: gongtom
Print fearture 7 years 9 months ago #14155
  • gongtom
Thanks for the reply.
Ok, I understand that.
May I ask another quesstion:
Is it possible to have a zoom feature to zoom into pdf in the uwp pdfviewer like you can zoom in android and ios?
Thomas.
