Error when removing annotations 4 years 8 months ago #15652
  • никкуз1
  • никкуз1's Avatar Topic Author
Hi.
I open pdf via PDFStream.
public class DecryptPdfStream : PDFStream
        public const int BLOCK_SIZE = 4096;
        private Stream m_stream = null;
        private char m_key;
        private bool m_fix = false;
        public void Open(Stream stream, String key)
            m_stream = stream;
            m_key = key.ToCharArray();
            string type_name = m_stream.GetType().ToString();
            m_fix = (type_name.LastIndexOf("NativeFileStream") > 0);
        public bool Writeable()
            if (m_stream == null) return false;
            return m_stream.CanWrite;
        public long GetLength()
            if (m_stream == null) return 0;
            return m_stream.Length;
        public long GetPosition()
            return m_stream.Position;
        public bool SetPosition(long pos)
            if (m_fix)
                ulong uoffset = (ulong)pos;
                ulong fix = ((uoffset & 0xffffffffL) << 32) | ((uoffset & 0xffffffff00000000L) >> 32);
                m_stream.Seek((long)fix, SeekOrigin.Begin);
            else
                m_stream.Seek(pos, SeekOrigin.Begin);
            return true;
        public int Read(byte buf)
            int read = m_stream.Read(buf, 0, buf.Length);
            return read;
// read encrypted pdf...
        public int Write(byte buf)
            long prev = m_stream.Position;
            m_stream.Write(buf, 0, buf.Length);
            return (int)(m_stream.Position - prev);
        public void Close()
            if (m_stream != null)
                m_stream.Dispose();
                m_stream = null;
        public void Flush()
                m_stream.Flush();
            if (file != null)
                IRandomAccessStream stream = await file.OpenAsync(FileAccessMode.ReadWrite);
                if (stream != null)
                    DecryptPdfStream decryptPdfStream = new DecryptPdfStream();
                    string accessToken = App.RestUserRepository.User.AccessToken;
                    string key = accessToken.Substring(0, 16);
                    decryptPdfStream.Open(stream.AsStream(), key);
                    return decryptPdfStream;
m_doc = new PDFDoc();
PDF_ERROR err = m_doc.OpenStream(m_stream, "");
m_view.vOpen(m_doc, 4, 0xFFCCCCCC, this);
I am successfully creating an annotation with text highlighting. I can save pdf with changes. But I cannot remove annotations
        public void OnPDFAnnotClicked(PDFPage page, PDFAnnot annot)
            m_view.vAnnotRemove();      or       annot.RemoveFromPage();
I am getting unhandled exception.
System.AccessViolationException: 'Attempted to read or write protected memory. This is often an indication that other memory is corrupt.'
I also tried to work with non-encrypted pdfs using a stream. The same error.
Last edit: by никкуз1.
Error when removing annotations 4 years 8 months ago #15653
dear user:
what version are you using? the last version on my side seems no method vAnnotRemove()
and we sure, that remove annotation works fine.
