addAnnotBitmap doesn't work in 2.2.0 12 years 1 month ago #6409
is it this?
BOOL result = [page addAnnotBitmap:mat :ref :YES :&rect];
addAnnotBitmap doesn't work in 2.2.0 12 years 1 month ago #6414
  • Rossi
  • Rossi's Avatar Topic Author
Are you saying I should use mat instead mat.handle?
In this case, mat is a PDFMatrix and addAnnotBitmap need a PDF_MATRIX.
addAnnotBitmap doesn't work in 2.2.0 12 years 1 month ago #6424
hi,
try to save m_doc before [self refresh]
addAnnotBitmap doesn't work in 2.2.0 12 years 1 month ago #6431
  • Rossi
hi, crashes evenly.
addAnnotBitmap doesn't work in 2.2.0 12 years 1 month ago #6479
  • stronglee
  • stronglee's Avatar
  • Thank you received: 2
Try iOS PDFViewer SDK 3.0.2 version. :-)
addAnnotBitmap doesn't work in 2.2.0 12 years 1 month ago #6531
  • Rossi
i tried the new sdk, it is better in may aspect but i have the same problem within add a bitmap.
I set the cache file in pdfOpen:
if(SYS_VERSION>=7.0)
        m_view = [[PDFView alloc] initWithFrame:CGRectMake(0, 0, rect.size.width, rect.size.height)];
    else
        m_view = [[PDFView alloc] initWithFrame:CGRectMake(0, 0, rect.size.width, rect.size.height-20-44)];
    NSString *cachesPath = [NSSearchPathForDirectoriesInDomains(NSDocumentDirectory, NSUserDomainMask, YES) objectAtIndex:0];
    cachesPath = [cachesPath stringByAppendingPathComponent:@"file.dat"];
    [m_doc setCache:cachesPath];
    [m_view vOpen :m_doc :(id<PDFViewDelegate>)self];
In onsigletapped i insert this line
[m_view vAddAnnotBitmap:x y:y image:myimage];
and this is the vAddAnnotBitmap implemented in PDFView
struct PDFV_POS pos;
    [m_view vGetPos:&pos:x:y];
    if(pos.pageno>=0)
        PDFVPage *vpage = [m_view vGetPage:pos.pageno];
        PDFPage *page = [vpage GetPage];
        PDF_RECT rect;
        rect.bottom = 300;
        rect.left = x;
        rect.right = y;
        rect.top = 100;
        if( page != NULL )
            CGImageRef ref = [image CGImage];
            PDFMatrix *mat = [vpage CreateInvertMatrix:self.contentOffset.x * m_scale :self.contentOffset.y * m_scale];
            BOOL result = [page addAnnotBitmap0:mat :ref :YES :&rect];
            //BOOL result = Page_addAnnotBitmap(mat.handle, mat.handle, ref, 1, &rect);
            Matrix_destroy(mat.handle);
            [m_view vRenderSync:pos.pageno];
            [m_doc save];
            [self refresh];
