addAnnotBitmap doesn't work in 2.2.0 12 years 1 month ago #6379
when you add a bitmap, you have to set "has_alpha" parameter to true, in Page_addAnnotBitmap method.
I also tried to add a png with transparent background with success
addAnnotBitmap doesn't work in 2.2.0 12 years 1 month ago #6386
  • Rossi
  • Rossi's Avatar Topic Author
ok, now also i add successfully png with transparent background, but app crash frequently at this function
-(bool)IsFinished
if( m_cache )
return [m_cache Stat] == 1;
if( m_thumb )
return [m_thumb Stat] == 1;
return true;
in PDFVPage on
with EXEC_BAD_ACCESS error
Last edit: by Abdikayrov.
addAnnotBitmap doesn't work in 2.2.0 12 years 1 month ago #6401
It crashes when you add a bitmap? or in another case?
There is a specific sequence to get this crash?
addAnnotBitmap doesn't work in 2.2.0 12 years 1 month ago #6402
  • Rossi
Yes, it crash when i add the bitmap. I add the bitmap the page begin the render but crash before showing the image.
addAnnotBitmap doesn't work in 2.2.0 12 years 1 month ago #6403
i think you shall add bitmap first, then, invoke vRenderSync to re-render the page.
addAnnotBitmap doesn't work in 2.2.0 12 years 1 month ago #6407
  • Rossi
I not find vRenderSync function.
This is my code:
CGImageRef ref = [[UIImage imageNamed:@"emoticon"] CGImage];
PDFMatrix *mat = [vpage CreateMatrix];
BOOL result = [page addAnnotBitmap:mat.handle :ref :YES :&rect];
Matrix_destroy(mat.handle);
[m_view vRenderPage:pos.pageno];
[self refresh];
