addAnnotBitmap doesn't work in 2.2.0 12 years 1 month ago #6539
try this:
struct PDFV_POS pos;
[m_view vGetPos:&pos:x:y];
if(pos.pageno>=0)
PDFVPage *vpage = [m_view vGetPage:pos.pageno];
PDFPage *page = [vpage GetPage];
PDF_RECT rect;
rect.bottom = 300;
rect.left = x;
rect.right = y;
rect.top = 100;
if( page != NULL )
CGImageRef ref = [image CGImage];
PDFMatrix *mat = [vpage CreateInvertMatrix:self.contentOffset.x * m_scale :self.contentOffset.y * m_scale];
[mat TransformRect : &rect ];
BOOL result = [page addAnnotBitmap: ref :YES :&rect];
Matrix_destroy(mat.handle);
[m_view vRenderSync:pos.pageno];
[m_doc save];
[self refresh];
addAnnotBitmap doesn't work in 2.2.0 12 years 1 month ago #6544
  • Rossi
  • Rossi's Avatar Topic Author
No, it doesn't work. It's the same before, the first insert is ok but the others crashes the app.
addAnnotBitmap doesn't work in 2.2.0 11 years 11 months ago #6773
  • Rossi
Hi, there is news about this problem? I use the latest beta release but the problem persist.
addAnnotBitmap doesn't work in 2.2.0 11 years 11 months ago #6776
Page object obtained from PDFVPage are not persist object.
you shall always get Page object from PDFVPage every time.
Page object obtained from PDFVPage will freed after vRender invoked.
addAnnotBitmap doesn't work in 2.2.0 11 years 11 months ago #6814
  • Rossi
Well, I do understand this but, the point is a crash in accessing m_cache status after I had a bitmap annotation.
It seems that the problem is connected with this line of code:
Commenting it out, we have no immediate crash with EXC_BAD_ACCESS, but I guess this could cause memory problems later?
