PDFGlobal.SetCMapsPath crash 9 years 21 hours ago #11773
  • YannV
  • YannV's Avatar Topic Author
I don't know what to do, I have an exception on PDFGlobal.SetCMapsPath(inst_path + "\\Assets\\cmaps.dat", inst_path + "\\Assets\\umaps.dat");
System.TypeLoadException
StackTrace = " at System.StubHelpers.StubHelpers.GetWinRTFactoryObject(IntPtr pCPCMD)\r\n at RDPDFLib.pdf.PDFGlobal.SetCMapsPath(String cpath, String upath)\r\n at SalesApp.Common.InitRadaee.AppOnLaunched()"
The two files are in the installed directory, my package name is 2625.RadaeePDFReader
I don't if I am doing good concerning the reference to the lib RDPDFLib. When adding the win32 RDPDFLib.dll (and set the target plateform to X86) I have a Visual Studio message error :
When adding RDPDFLib.winmd Visual studio is not complaining, the code build.
I am not familiar with the .winmd, could someone tell me what I am doing wrong ?
PDFGlobal.SetCMapsPath crash 8 years 11 months ago #11777
It seems like you are not correctly setting the configurations of the reference,
Make sure that for the reference RDPDFLIb , you have (Copy Local) set with true (Check the demo project for a guide)
PDFGlobal.SetCMapsPath crash 8 years 11 months ago #11781
  • YannV
Hi, thanks for your reply.
I restart from scratch. I have a solution with 3 projets (Winrt). Buiklding Runing ok (Debug - ANY CPU)
I have added RDPDFLib projet in my solution.
I have added reference in my WinRT project to the project RDPDFLib
I start a build :
The file :\SalesApp\Debug\RDPDFLib\RDPDFLib.winmd doesn't exist.
In the demo solution, the Debug folder is well generated
In my solution, this folder is "half" generated, ending with the error above.
Here is the folder
And the one inside the demo :
So, I cannot generate debug folder correctly. Why ?
Thanks for your help.
Regards,
Yann
PDFGlobal.SetCMapsPath crash 8 years 11 months ago #11782
And what are the reference properties for RDPDFLIB?
PDFGlobal.SetCMapsPath crash 8 years 11 months ago #11783
  • YannV
looks the same to you.
PDFGlobal.SetCMapsPath crash 8 years 11 months ago #11784
  • YannV
looks the same as you.
