PDFGlobal.SetCMapsPath crash 9 years 5 months ago #11787
  • YannV
  • YannV's Avatar Topic Author
OK, here is the solution
the lib directory needs to be copy with the projet at the same directory level :
Then, edit build configuration and check "Win32" build checkbox for RDPDFLib
Then, it is not possible to run in "Any CPU" anymore, select X86 or another plateform CPU.
