Convert PDF coordinates to view layout coord 8 years 10 months ago #12883
  • geertvm
  • geertvm's Avatar Topic Author
I have a custom layout (RelativeLayout) which holds a PDFLayoutView
and a custom toolbar (also a RelativeLayout with some imagebuttons)
First of all I want to detect if the user tapped on a visible signature field.
I think we can handle that by implementing the setOnTouchListener and converting the raw x and
y coordinates with the PDFLayout.PDFPos pdfPos = m_view.PDFGetPos(x, y);
I also want to draw some kind of overlay on visible signature fields (with known PDF coordinates).
I've started by implementing the PDFLayoutView.PDFLayoutListener() and the OnPageDisplayed
So I suppose it could be possible to draw a rectangle on the canvas...
How can I convert these PDF coordinates to the layout coordinates so that I can draw an rectangle on top of a visible signature field
(It's possible that this field is only visible after some scrolling...)
Geert
Convert PDF coordinates to view layout coord 8 years 10 months ago #12887
You can implement PDFLayoutListener.OnPDFAnnotTapped (which get fired when an annot is tapped) and filter based on Annot type and annot filed type to detect a signature field.
You can also get the annotation rectangle (position) in PDF coordinates and convert it to view coordinates to be used later in OnPageDisplayed, check the below code:
	public void OnPDFAnnotTapped(VPage vpage, Annotation annot)
		if(annot != null && annot.GetType() == 20 && annot.GetFieldType() == 4) {
			float[] annotRect = annot.GetRect();
			float tmp = annotRect[1];
			annotRect[0] = vpage.GetVX(annotRect[0]) - m_view.PDFGetX();
			annotRect[1] = vpage.GetVY(annotRect[3]) - m_view.PDFGetY();
			annotRect[2] = vpage.GetVX(annotRect[2]) - m_view.PDFGetX();
			annotRect[3] = vpage.GetVY(tmp) - m_view.PDFGetY();
Note: m_view.PDFGetX() and m_view.PDFGetY() are introduced in the latest version 3.14.2, you can add them in PDFLayoutView:
public float PDFGetX() {
		return m_layout != null ? m_layout.vGetX() : 0;
	public float PDFGetY() {
		return m_layout != null ? m_layout.vGetY() : 0;
Convert PDF coordinates to view layout coord 8 years 10 months ago #12888
  • geertvm
The digital signature field isn't recognized...
but the code helped me in displaying the overlay...
Convert PDF coordinates to view layout coord 8 years 10 months ago #12891
The pdf you have sent does not contain a signature field (it only contains a text).
As a consequence the code above wont work.
Same behavior with Acrobat and other readers.
Convert PDF coordinates to view layout coord 8 years 10 months ago #12893
  • geertvm
sorry, uploaded the wrong pdf... :(
This one has 2 visible signature fields...
Convert PDF coordinates to view layout coord 8 years 10 months ago #12894
We have tested your new pdf with the above code, and the annotations can be recognized.
Can you retest by adding the above code into the demo project?
