Convert PDF coordinates to view layout coord 8 years 9 months ago #13007
can you reproduce the issue with the demo project?
I can get the proper result in the onPostExecute() method of PDFViewAct :
m_view.PDFOpen(m_doc, PDFViewAct.this);
Page p = m_doc.GetPage0();
p.ObjsStart();
p.GetAnnotCount();
Toast.makeText(PDFViewAct.this, "Annot Count " + p.GetAnnotCount(), Toast.LENGTH_SHORT).show();
p.Close();
Convert PDF coordinates to view layout coord 8 years 9 months ago #13008
  • geertvm
  • geertvm's Avatar Topic Author
Not really...but can you indicate what's missing or wrong in the provided code?
Convert PDF coordinates to view layout coord 8 years 9 months ago #13009
  • geertvm
I can't simulate it in the sample but when I have the next code, the count = 0
m_view = (PDFLayoutView) findViewById(R.id.view);
m_asset_stream = new PDFAssetStream();
m_asset_stream.open(getAssets(), "tbs.pdf");
m_doc = new Document();
int ret = m_doc.OpenStream(m_asset_stream, "");
Log.d(TAG, "OpenStream: " + ret);
m_view.PDFOpen(m_doc, null);
p.ObjsStart();
int c = p.GetAnnotCount();
Log.d(TAG, "Count = " + c);
p.Close();
Convert PDF coordinates to view layout coord 8 years 9 months ago #13010
  • geertvm
This is working in the AboutActivity of RDPDFReader
protected void onCreate(Bundle savedInstanceState)
super.onCreate(savedInstanceState);
Global.Init(this);
m_view = new PDFLayoutView(this);
int ret = m_doc.OpenStream(m_asset_stream, null);
ProcessOpenResult(ret);
if(ret == 0)
setContentView(m_view);
p.ObjsStart();
int c = p.GetAnnotCount(); // -> 2
p.Close();
This isn’t working
In my MainActivity…
protected void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.activity_main);
Toolbar toolbar = (Toolbar) findViewById(R.id.toolbar);
//setSupportActionBar(toolbar);
Global.Init(this);
p.ObjsStart();
int c = p.GetAnnotCount(); // -> 0
p.Close();
With
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="schemas.android.com/apk/res/android"
android:id="@+id/ctrllayout"
android:layout_width="match_parent"
android:layout_height="match_parent">
<com.radaee.reader.PDFLayoutView
android:id="@+id/view"
android:layout_above="@+id/sctoolbar">
</com.radaee.reader.PDFLayoutView>
<RelativeLayout
android:id="@+id/sctoolbar"
android:layout_height="wrap_content"
android:layout_alignParentBottom="true"
android:background="@drawable/customborder">
<ImageButton
android:id="@+id/arrleft"
android:layout_width="wrap_content"
Convert PDF coordinates to view layout coord 8 years 9 months ago #13011
As we cannot reproduce the issue with the demo project, can you send us a sample project (activated with the demo license) that can be used to investigate this problem?
Convert PDF coordinates to view layout coord 8 years 9 months ago #13015
  • geertvm
The demoproject can be downloaded from
www.dropbox.com/s/gphhpuwyl8nvmkd/PdfView.zip?dl=0
(Could not upload it...)
