Convert PDF coordinates to view layout coord 8 years 9 months ago #12993
  • geertvm
  • geertvm's Avatar Topic Author
Related to this overlay...I had to change the PDFLayoutView by adding the OnPageDisplayed() in the PDFLayoutListener interface.
This way I can add some info on the canvas when the page is displayed. Can it be part of the next release?
Convert PDF coordinates to view layout coord 8 years 9 months ago #12995
Ok it will be part of the next release.
public interface PDFLayoutListener
		void onPDFPageDisplayed(Canvas canvas, VPage vpage);
Convert PDF coordinates to view layout coord 8 years 9 months ago #12997
  • geertvm
Thanks...
Is there a way to
1. get a list of all signature fields (visible and invisible)
2. get the PDF coordinates of visible signature fields.
Convert PDF coordinates to view layout coord 8 years 9 months ago #12998
you can get the annotations using page.GetAnnot(int index)
For more info check this : www.radaeepdf.com/documentation/javadocs...e.html#GetAnnot-int-
Then you can check the annot type, coordinates and status (visible or invisible etc..) using the following methods :
annot.GetType();
annot.GetFieldType();
annot.GetRect();
annot.IsHide();
Combining these methods, you wil get what you want..
Convert PDF coordinates to view layout coord 8 years 9 months ago #12999
  • geertvm
I've tried
Page p = m_doc.GetPage0();
int i = p.GetAnnotCount();
It gives me 0 annotations (with the document I've sent before)
This has 2 visible signature fields...
Convert PDF coordinates to view layout coord 8 years 9 months ago #13000
  • geertvm
I suppose this is a license issue...
Is it possible to evaluate the professional licence?
