Convert PDF coordinates to view layout coord 8 years 3 months ago #13769
can you please better explain the first part of the post?!
GetType() and GetFieldType() return an int so you can use the "==" operator to compare the results.
annotRect are coverted in pdf coordinates, if you want the X and Y, you should use :
annotRect[0] --> X
annotRect[1] --> Y
Convert PDF coordinates to view layout coord 8 years 3 months ago #13770
  • mfranc28
  • mfranc28's Avatar
My code:
public void OnPDFAnnotTapped(VPage p0, Annotation p1)
if (p1 != null && p1.GetType() == 20 && p1.GetFieldType() == 4)
float[] annotRect = p1.GetRect();
float tmp = annotRect[1];
annotRect[0] = p0.GetVX(annotRect[0]) - rPdfLayoutView.PDFGetX();
annotRect[1] = p0.GetVY(annotRect[3]) - rPdfLayoutView.PDFGetY();
annotRect[2] = p0.GetVX(annotRect[2]) - rPdfLayoutView.PDFGetX();
annotRect[3] = p0.GetVY(tmp) - rPdfLayoutView.PDFGetY();
Red Ones: Visual Studio give me error: Operator '==' cannot be applied to operands of type 'Type' and 'int'
Blue ones: Visual Studio give me errore: 'Page.Annotation' does not contain a definition for 'GetTypeField' and no extension method 'GetFieldType' accepting a first argument of type 'Annotation' could be found
Instead I have to write this:
if (p1 != null && p1.Type == 20 && p1.FieldType == 4)
I missing something?
Last edit: by mfranc28.
Convert PDF coordinates to view layout coord 8 years 3 months ago #13771
is correct if you are implementing in native java.
In case of Xamarin.Android, it becomes:
The following user(s) said Thank You: mfranc28
