Page position on zoom 11 years 3 months ago #7530
  • Rossi
  • Rossi's Avatar Topic Author
Hi,when I zoom the page is not center where I zooming but the page is zoomed in section. The result is that I can't do with zoom an annotation in same section of the page because this is not visible in the same momemnt.
I use the latest beta release.
Page position on zoom 11 years 3 weeks ago #8258
  • dilawer
  • dilawer's Avatar
Hi Team,
I am having the same problem. Can you please let me know what could be the possible solution ?
When I zoom a page, it do not stand still on the same area. It moves to another location after zooming. It happens only when I set paging enable. In PDFView, I set self.pagingEnabled=YES. Otherwise zooming is good but I need zooming and paging both.
Please send a quick response.
Page position on zoom 11 years 3 weeks ago #8263
you can try to disable pagingEnabled in scrollViewDidZoom method, and set it to YES at the end of scrollViewDidEndZooming method if self.zoomScale <= 1 (if entire page is shown).
If the page is not centered when you zoom out, you can also call vGoto.
in scrollViewDidEndZooming you should add something like:
if (self.zoomScale <= 1)
        self.pagingEnabled = YES;
        [self vGoto:m_cur_page];
Page position on zoom 11 years 2 weeks ago #8271
  • dilawer
  • dilawer's Avatar
Thanks for a quick update. I will try this and will respond back. But I am also expecting a fix for this in next reader update. Please confirm reader team will fix this ?
Page position on zoom 10 years 11 months ago #8446
  • wdbutt
  • wdbutt's Avatar
Hi Emanuele,
I did code as you instruct in you solution, you can see in my code image (cloudup.com/cHj2prHEQmI). But I'm facing problem. When I zoom out, I am taken to a different page. Please give proper solution asap.
Page position on zoom 10 years 11 months ago #8447
please check the last version, that integrate some zoom improvements.
You can download it here
