Page position on zoom 11 years 5 months ago #8522
  • imran.nazeer
  • imran.nazeer's Avatar
This line keeps coming when i open pdf-viewer
(705,0x109594000) malloc: *** mach_vm_map(size=1408221184) failed (error code=3)
*** error: can't allocate region
*** set a breakpoint in malloc_error_break to debug
Feb 16 16:55:21 [705] <Error>: CGImageCreate: invalid image size: 0 x 0.
Last edit: by imran.nazeer.
Page position on zoom 11 years 5 months ago #8523
This is the code that you should use to block the page scrolling while the page is zoomed, in this particular case, when viewMode = 4 (for viewMode = 3 you have to use the code in KB).
We are working also to fix the 64-bit devices issue.
Your error is due to viewMode that you're using (you should follow the KB instruction)
Page position on zoom 11 years 5 months ago #8524
  • imran.nazeer
After inserting the code from KB, am getting that errors.
Mine is "m_view = [[PDFVVert alloc] init];"
Am using vertical mode. How can avoid this issue. Tomorrow I have to submit it to app store.
Page position on zoom 11 years 5 months ago #8526
  • imran.nazeer
Please give a solution for 64 bit architecture. We are unable to submit the app to appstore
Page position on zoom 11 years 5 months ago #8530
A new version is now available here
It fixes a zoom issue and contains lib updates.
Page position on zoom 11 years 5 months ago #8533
  • imran.nazeer
@Emanuele - It is not fixed for 64 bit apps.
Change into this configuration -> Valid Architectures -> add arm64
The bug will exist still.
Please check screenshot.
Today too I cant submit to app store :(
