Page position on zoom 11 years 5 months ago #8472
Paging is in beta, so I suggest to disable it.
to disable paging, set g_paging_enabled = false; at the end of APP_Init method.
We are working on it, and we will release a stable version as soon as possible.
Page position on zoom 11 years 5 months ago #8479
  • wdbutt
  • wdbutt's Avatar
Hi Emanuele
I again test your latest version as you told me. But facing same problem. I attach my crash report (cloudup.com/cjzKJDyX0nQ) please check this and update me. One thing more, The version you are suggested me is 3.3.o as you can see in image (cloudup.com/cG6ZNBJsQYp)(i.e. after extracting your latest build) but In project there is 3.0 version so also see and also update on page adjustment of magzine.
Last edit: by wdbutt.
Page position on zoom 11 years 5 months ago #8480
to understand the problem, can you give us some informations?
which view mode are you testing? Have you disabled paging as I suggest? Are you using double or single page mode?
The crash happen when you start to search or when you tap the left arrow button (prev search result)?
We try to search some text present in previous pages (for example: going to page 5 and search a word present in page 2), but we can't reproduce the crash.
Did you try with different pdf or always with the same? If the crash happen only with a specific file, we can check it and fix the problem.
At the moment we are going to finish some implementations to fix page adjustment.
Page position on zoom 11 years 5 months ago #8481
  • wdbutt
  • wdbutt's Avatar
I'm using Horizontal mode and using single page mode and only tap on search button and getting crash. I’m also test that with different magzine pdf but getting same bug. I’m also disable paging but it cannot set the page size on screen. When did I expect to get a stable version of RadaeePDF ?
Page position on zoom 11 years 5 months ago #8484
we publish the 3.3.0 beta3 version, you can download it here
Please, check if your problem has been solved.
We are trying to solve search, rotation and paging issues before release the stable version.
Page position on zoom 11 years 5 months ago #8488
  • wdbutt
  • wdbutt's Avatar
No my problem is still not solved. I can show you the code line on which RadaeePDF is crashed in this image (cloudup.com/ci_bvJ1iWSe/f). Now please inform me when you release stable version. So only then I can test your RadaeePDF with all bugs fixed.
