Page position on zoom 11 years 5 months ago #8457
  • wdbutt
  • wdbutt's Avatar
Hi Emanuele,
I also integrate and test the latest version of Radaeepdf. But I'm facing many problems on it like zoom out I am taken to a different page did to working in latest version, Searching Feature of Radaeepdf not working well, I also post that problem on forum but they did not give me proper solution you can see on this link (www.radaeepdf.com/forum/ios-dev/2310-sea...pdf-not-working-well), if you change the orientation of device to landscape, RadaeePDF did not set the pages of document as you can see in this image (cloudup.com/cLYwQ5IoYnr), and if I’m on page number 6 and change the orientation to landscape it goes to first page and vice versa. Problem with Links on iPad Air (www.radaeepdf.com/forum/ios-dev/1645-pro...th-links-on-ipad-air ), support team did not give proper solution on that.
Now I’m using RadaeePDF version 3.0.6 and also test 3.2.0 but facing same problem. I’m old user of your product (RadaeePDF). Please refer me proper solution on it asap.
Last edit: by wdbutt.
Page position on zoom 11 years 5 months ago #8459
  • Cooper
  • Cooper's Avatar
We are facing all problems that are mentioned in the reply above. We have purchased 3 iOS licenses almost a year ago and would expect such serious bugs to be solved by now. As per the current situation, I would not recommend anyone to purchase a license. Please give a solution a.s.a.p.
Bob
Page position on zoom 11 years 5 months ago #8461
we are fixing zoom and rotation problems, today we will release a fixed version
Page position on zoom 11 years 5 months ago #8466
a new beta version is now available here:
  • It fix some problems:
  • rotation issue
  • zoom out issue
  • search issue
thank you for your feedback that helps to fix SDK issues
Page position on zoom 11 years 5 months ago #8468
  • wdbutt
  • wdbutt's Avatar
Hi
I test latest build of RadeePDF but got crash on searching. If I’m on 3rd last page and search some text which is present in 1st page then app crash. One more thing is my magzine page did not adjust according to screen you can see on this image (cloudup.com/cGxD_0aC3vJ). So please give me proper solution.
Page position on zoom 11 years 5 months ago #8470
a new version with search fix is available here
we fix prev search bug and remove the delay when try to search for the first time
